Hi Every one anyone has Concrete I beam cell with varies input so i can use for my work.
Best Regards
We do not have a concrete I section in our current datasets. However we are about to release OpenBuildings Designer Update 7 which will include new structural modelling capabilities that make it possible for users to create custom structural sections.
Marc
Hi Sir
Thanks for explanation. may i know when its gonna release any date month etc.
Dear Sir any easy way to model below with any dimensions just need technique needed.
if its not related to you can you please refer someone expert to demonstrate a method to do that.
Best Regards.
Muhammad Ismail
I have modeled the beam with solid tools (extract a solid for the concrete savings),
then I have saved the different beams in a normal cell libraryand saved them to architectural objectsthen you can place them with the "place object tool"
for those who want some objects like these i've included my cell lib.VCA_GC01.cel
if someone have a better solution ( these objects are NOT parametric) please let me know
In this case it is not a simple extrusion of a profile so my previous comment would not apply.
You could model this using parametric solids and constraints.
I may have an example for you later.
ok please.
thanks
