Hi,Open Building Designer doesn't exit anymore. I have to use 'Control Alt Delete' and finish the task.Hope somebody knows why?regards,Marc Vossen
Hi Marc,
Can you elaborate on the nature of the issue? For example, are there any error messages or warnings? Does the UI hang? Things like that.
Also :
Are you carrying out a particular task when this behaviour arises?
Is this happening with specific files or any file?
Does it just happen to your machine or to others too?
Which version of Windows?
Marc
Dear Steve,
it happens when I start ABD and in my ABD session I open Apache Open Office (Yes, I am not using Excel,Word from windows). When I don't open Open Office it 'exits' normally. But before it never gave problems. I think I am going to install Open Office again.
kind regards, Marc Vossen Here under my error messages in red: Cope Dependencies are disabled. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. WARNING: Duplicate section name encountered. Reading Section SCHEMAMANAGERADDIN loaded.
Update from Bentley Communities Steve Cocchi Hi Marc, Can you elaborate on the nature of the issue? For example, are there any error messages or warnings? Does the UI hang? Things like that. View online You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here. Flag this post as spam/abuse.
View online
Dear Marc,
I am using only one machine with Windows 10 Home and it happens when I start ABD and in my ABD session I open Apache Open Office (Yes, I am not using Excel,Word from windows). When I don't open Open Office it 'exits' normally. But before it never gave problems. I think I am going to install Open Office again.
Update from Bentley Communities Marc Thomas Hi Marc, Also : Are you carrying out a particular task when this behaviour arises? Is this happening with specific files or any file? Does it just happen to your machine or to others too? Which version of Windows? View online You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here. Flag this post as spam/abuse.
H Marc,
Two separate issues here.
We don't support Open Office, our testing and integration is with Microsoft Office (e.g. the Edit in Excel feature in the Schedules dialog). Repairing Open Office may well resolve the problem.
The warning errors indicate that somewhere in your dataset< WorkSpace or WorkSets there are duplicate XML entries for some sections. The Message Center will give more information. This is probably a duplicated XML file that you should be able to identify and remove.
