I have a project, with a working grid and floors setdrawings (floor plans and elevations) have shown the grid (at project start up)
with no reason (i think) the grid is now not showing the correct information:i have made a new plan section, and created a new drawing:my saved view in 3D container looks like this:the drawing like this:
the grid lines (plan section) are disappeared, and elevation level symbols are placed on top of each other (every floor annotation at the same place)so the drawing seems to ask for elevation grid lines, but knows all floors are shown from above - plan view.
the drawings from the saved views are made correct (I think) (just the same as the older correct working drawings)
what can be wrong, how to correct
an older drawing from the same model is still working correct:
OBD 10.6.03.04 (latest)
who can help
Regards Rik
Hi Rik,
That is odd. Obviously something has changed to cause that behavior, but what... Have any scale settings changed? What happens if you use a Plan seed instead of Section, or vice versa?
