Good Morning
I have just tried to install the new update 7 and have run into a problem
I get this Failure after going through and selecting the correct dataset
I have installed the update 7 over update 6 with the same result.
Also done a uninstall of the program and fresh install with the same result.
Can someone tell me what I am doing wrong or missing
cheers
From your first screenshot is the S Drive perhaps a network mapped drive? If so you may want to check you have the appropriate permissions to the location.
yes the S:/ is a mapped network drive and yes i do have all the appropriate permissions to the location
Hi Ben,
To support the ProStructures technology that now underlies OBD's structural tools we copy additional content into an existing configuration and replace the dataset.cfg file with a new one that includes additional configuration statements required to locate ProStructures resources. (I'm assuming that we simply replace the file, I'll check to confirm this. If we write the required statements to the existing file it is possible that different permissions might apply.)
If you install U7 and datasets locally you will find the required content on your local drive that could then be copied to the network. Note that there are other changes to the datasets listed in the delta change document in each dataset root folder.
Which dataset(s) are you installing?
Marc
I am trying to install the New Zealand Dataset.
If I install U7 locally and copy over the dataset files to my network, will U6 program still function as normal. Just because we have 4 other computers using the network files and they wont be upgrading for a couple months due to being in the middle of a job.
Ben
The application and dataset versions should match.
If you need to run two versions (and currently only one CONNECT version at a time can be installed on a machine) we recommend separate Custom Configurations for each.
You should maintain your current configuration for the Update 6 users.
Here is an outline of one suggested approach to this upgrade (these are notes I'm drafting for a new wiki so are incomplete but should offer a direction, hopefully the wiki article will be completed by early next week):
Outline steps
(I'm currently writing detailed steps to follow on from this outline, I hope these notes are useful in the meantime.)
