I can create .ivr-files with ABD fine.
But I find no program to view them?
It fails for me with Realplayer.
Any suggestion is welcome.
Regards//Thomas Voghera
I tried downloading RealPlayer yesterday but was warned off the download by my web browser. Also I don't know if RealPlayer continues to support the format.
Marc
If i remember correctly quicktime could also open ivr files. support for it has ended though:
https://communities.bentley.com/products/microstation/w/microstation__wiki/31079/quicktime-for-windows-support-ends-and-effect-on-powerplatform-products
You might be able to find an installation for it but would be very cautious as there are some vulnerabilities in quicktime that were never fixed.
If you need to create a panorama would suggest looking into LumenRT where you can create a panoramic video that can be shared over youtube.
https://communities.bentley.com/products/microstation/microstation_visualization/w/microstation_visualization_wiki/34378/how-to-export-to-360-degree-vr-panoramic
All - I found the same - to bad. They were easy to do and easy to use.
I think I go for a 3d-pdf and some Saved Views as I am still on ABD. Problem is it is easy to make more movment than panning.
David - do you have an example of a 'panoramic video'/spherical video from inside a room made with Microstation?
//Thomas
regards / Thomas Voghera
Came across this
https://my.matterport.com/show/?m=d42fuVA21To
You can do that with ContextCapture, there is a free mobile app.
Meshes can be referenced or imported into ABD.
