After updating to the latest version of openbuildings, I get the following "configuration audit alert" when opening any dgn file (new or existing):
WorkSpace 'AECOsimExamples'/WorkSet 'BuildingTemplate_US' does not define an adequate configuration for ProStructures.
Details are as follows:
_USTN_WORKSPACENAME = AECOsimExamples_USTN_WORKSETNAME = BuildingTemplate_US
PS_MATERIALFILE = C:\ProgramData\Bentley\AECOsim CONNECT Edition\Configuration\WorkSpaces\AECOsimExamples\Standards\ProStructures\USA_Canada_Imperial\Data\ProStructuresMaterial.mdb Evaluation finds no files
PS_BOLTINGASSEMBLIES = C:\ProgramData\Bentley\AECOsim CONNECT Edition\Configuration\WorkSpaces\AECOsimExamples\Standards\ProStructures\USA_Canada_Imperial\MechanicalFasteners\Bolts\ No files with extension .bsy are found
PS_BOLTINGASSEMBLIESLIST = C:\ProgramData\Bentley\AECOsim CONNECT Edition\Configuration\WorkSpaces\AECOsimExamples\Standards\ProStructures\USA_Canada_Imperial\MechanicalFasteners\Bolts\PsBoltList.bls File does not exist
PS_CODESSELECTION = C:\ProgramData\Bentley\AECOsim CONNECT Edition\Configuration\WorkSpaces\AECOsimExamples\Standards\ProStructures\USA_Canada_Imperial\Rebar\PcCodeSettings.xml File does not exist
PS_POSITIONFLAGSTYLES = C:\ProgramData\Bentley\AECOsim CONNECT Edition\Configuration\WorkSpaces\AECOsimExamples\Standards\ProStructures\USA_Canada_Imperial\PositionFlags\ No files with extension .psy are found
PS_DETAILSTYLES = C:\ProgramData\Bentley\AECOsim CONNECT Edition\Configuration\WorkSpaces\AECOsimExamples\Standards\ProStructures\USA_Canada_Imperial\Details\Styles\ No files with extension .stx are found
PS_DRAWINGFRAMEDEFINITION = C:\ProgramData\Bentley\AECOsim CONNECT Edition\Configuration\WorkSpaces\AECOsimExamples\Standards\ProStructures\USA_Canada_Imperial\Details\ No files with extension .frm are found
PS_DRAWINGSCALETEMPLATE = C:\ProgramData\Bentley\AECOsim CONNECT Edition\Configuration\WorkSpaces\AECOsimExamples\Standards\ProStructures\USA_Canada_Imperial\Details\ No files with extension .scl are found
PS_ELEVATIONFLAGSTYLES = C:\ProgramData\Bentley\AECOsim CONNECT Edition\Configuration\WorkSpaces\AECOsimExamples\Standards\ProStructures\USA_Canada_Imperial\ElevationFlags\ No files with extension .ksy are found
PS_PARTLISTTEMPLATES = C:\ProgramData\Bentley\AECOsim CONNECT Edition\Configuration\WorkSpaces\AECOsimExamples\Standards\ProStructures\USA_Canada_Imperial\Partlist\ No files with extension .lst are found
PS_CONCRETEPARTLISTTEMPLATES = C:\ProgramData\Bentley\AECOsim CONNECT Edition\Configuration\WorkSpaces\AECOsimExamples\Standards\ProStructures\USA_Canada_Imperial\Partlist\Concrete\ No files with extension .lst are found
REBAR = C:\ProgramData\Bentley\AECOsim CONNECT Edition\Configuration\WorkSpaces\AECOsimExamples\Standards\ProStructures\USA_Canada_Imperial\Rebar\ Directory does not exist
REBAR_PROJECT = C:\ProgramData\Bentley\AECOsim CONNECT Edition\Configuration\WorkSpaces\AECOsimExamples\Standards\ProStructures\USA_Canada_Imperial\Rebar\Detailing\Metric\ Directory does not exist
Hello Robert,
Are you getting this configuration audit alert after doing the Structural Dataset Upgrade ? Have you properly upgrade your structural dataset? Please check this to check whether it is updated properly or not?
Regards,Alifur
Also make sure the dataset you're pointing to is for U7 and not U6 - the latter will not include any ProStructures content.
Hi Robert,
I have faced the same issue after upgrading to latest OpenBuildings Update 7, but only with new Workset, which I was trying to create.
After some investigation and help from my colleague Marc Thomas, we discovered that new Workset is created with standard configuration, which is missing many important data required for it to work smoothly with Prostructures integration.
If you are facing this issue with new Workset, then you can fix this by just copying all content from existing workset's *.cfg file and pasting it into your own workstet's *.cfg.
After pasting everything from existing workset to my own one, OBD started opening all files from this new workset without any issues.
Hope this will help you.
Best Regards,Kestutis Mitkus
Application Engineer, Building, Structural & Plant
I also mentioned this in another thread, but I've created a wiki to address the Audit Alert message:
https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/51365/prostructures-configuration-audit-alert-message-after-opening-update-7-for-the-first-time
