After updating to the latest version of openbuildings, I get the following "configuration audit alert" when opening any dgn file (new or existing):
Details:
How do I reconfigure to get back in to my existing files?
Hi Robert,
I assume that you are able to use the 'Continue' button to get to your files?
Please refer to some of the information linked from the sticky post at the head of this forum, ProStructures Interoperability gives an overview, there is more detail in Structural Dataset Upgrade and the other help pages.
Marc
Also, make sure you're not pointing U7 to an existing U6 workspace- that will not include the required ProStructures content and associated configuration variables.
Hi
i had the issue above then worked out it was pointing to the U6 workspace - now its pointing to the right location.
the new issue is i dont have any member " shapes " when trying to pick a steel column, etc ( cant pick any UB at all )
Hi Ben,
Good to hear you got that part straightened out. In regards to shapes, the first question I have is whether you're in legacy mode or using the new ProStructures versions?
Hi Steve,
Can you tell me how I can work out what mode I am in ?
I have been able to get the 'NZ.mdb' database file to be read in OBD U7, I had to find the " PS_SHAPESDATABASES "
setting in the configuration variables and point it to the 'NZ.mdb'. ( don't ask me how I found it, I cant remember ) there seemed to be nothing set to this setting.
in regards to the NZ.mdb file, how can I add profiles to this file ? would really like to have 690UBs, 760UBs and HST Purlin profiles to choose from.
