Hi Guy,
I want to use OBD model hydro power plant but the concrete structures will include pouring concrete as below
The my workflow now I model concrete part by level of pour --> make pour break for part
Question is: in OBD how to make pouring concrete?
Hello Nguyen,Thanks for raising this questions. We're looking into this and will get back to you soon.Regards,Sayanti
Hi Nguyen,
I'm not entirely you what you mean by "model concrete part by level of pour --> make pour break for part", but in this example I created a 2D shape with holes and then used that to create a Slab using the Flood method. I suppose if you needed a group of individual slabs (?) you could split that initial shape into pieces and then create slabs from each one...
