XM: Catalog Information Not Appended
Bentley Architecture XM 08.09.04.46
Bentley TriForma XM 08.09.04.96
Bentley MicroStation 08.09.04.88
I have PAZ doors that are not holding DG data when the door is edited and DG data is filled out on existing DG fields.  In some cases, when I place a new door, I get "Catalog Information Not Appended" and the door is not able to be added to the DGN file
I don't see anything different about the catalog files, the users all have full r/w access to both the DGN files via PW and to the Catalog Data in the workspace.
I have put a support ticket in with TSG, but thought I would throw this out to the masses to see what came back.
Any thoughts would be most appreciative.
Shawn
  • This probably is something better suited to an more in-depth support review, but...  typically that message means that there's something "out of sync" in the DataGroup System.   IOW, the door was placed with one set of DG data, which by editing time has in some way changed.  Therefore we cannot append this new DG data since it doesn't "match" the existing data already present on that element.
  • This just happened to me.  I had checked hide pas, cell name and doorleafthickness.  When unchecked it worked.  I'm sure it was only one of these but not sure which
    Ustn since 1988
    SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64b
    Eric D. Milberger
    Architect + Master Planner + BIM
    Senior  Master Planner NASA - Marshall Space Flight Center
    The Milberger Architectural Group, llc
