How to fill out the "system" tab in COBie spreadsheet? (AECOsim Building Designer V8i)
Whenever i export a COBie spreadsheet, the "System" tab is always empty. How do i link the components to a system?
  • Do i have to define the system somewhere? I have multiple ducts, pipes and conduits modeled using AECOsim tools but nothing shows in the system tab when i export the COBie spreadsheet.
  • Hi Yehia,
    MEP system required system ID generated for all source [Ex. AHU ] and terminator device [Ex. Diffusers], once it is setup for your HVAC system , it will be exported as IFCSystem and populate COBIe system tab as shown below.
    To generate system ID there is a tool called 'System ID' in Route Assist ribbon group.
    HTH,
    Rg,
    Sandeep
  • Thank you Sandeep. I followed the steps. However; I keep getting "n/a" any idea?
  • Yehia , Please check out this video, you will get desired result.
    Best Regards,
    Sandeep
