How to make drawing model in sheet completly hidden lines
  • Hello Ismail,
    To make the drawing model completely in hidden line in the sheet you have to go the the drawing model which has been attached with the sheet. From that drawing model, go to references, and in the reference dialog click on the visible edges and from there go to visible edge settings and you can change the symbology in that settings. Once the changes have been made in the drawing model, it will automatically reflect on the sheet model. Please see the attached image.
    Alifur
