OpenBuildings Imodel Attachments
At the moment I am working on a project in which we need to produce a federated model that we end up exporting as an IFC.
We have done so successfully with each independent file, but when its time to create a federated model and attaching them all together some of the files for some reason come up as a 2D.
With some of the files, attaching them as an interactive reference and having their nested attachments in the live nesting option turned on  has turned out in a successful outcome. But for other links they will still come out in the model in a 2D representation.
Is there a known way to avoid this, setting them up in the coincident world and not as interactive wont help either.
Best regards and thanks for the help.
  • Hello Job,
    I would like to suggest you to look after all the reference files and their type of model files before attaching into reference. If they are all are 3D model files then I presume their might be any problem with those reference files. If you do not find any irrelevant file types still it is happening at your end, please raise a service ticket our technical team will look after this issue.
    Thanks & Regards,
    Arindam
