i have been working on a project for the last 6 weeks using OBD
During that time i have created OBD drawings and plotted them to PDF sucessfully
about 4 weeks ago now the PDF prints started printing all the PDF's grey
has anyone else encoutered this?
what is the fix?
Hi David,
Can you identify anything that changed 4 weeks ago? Who controls the print settings, you or the admin of the system you are working on?
Marc
apart from windows updates, there hasn't been any changes. the print settings were not changed.
i have passed the drawings back to the rest of the team and one of them pointed out it will print correctly if rasterised is clicked.
that definately wasnt the case three weeks ago
David Turner
MEP 3D coordination & BIM Technician
Rail Projects
OBD had a problem with printing from 3 (or 2?) till Update 5 if I'm correct, which was solved by using the 'rasterized' print option. Could be related? Which version are you on?
Windows 10 pro
OpenBuildings Designer Connect Edition 2023 | 23.00.00.114
