is it possible to export clashes detection result to BCF file ?
thanks
Please take a look at this Idea for Microstation and vote if it fits your needs: BCF manager | MicroStation Ideas Portal (aha.io)
What is BCF?
Dwg has the concept of Named Views. Can dgn-Saved Views be exported to dwg-Named Views I think it would be a fine route.
And then a macro/mdl that creates a saved view for each collision instance in the xls.
regards /Thomas Voghera
BCF is an open format for issue management. It saves both the viewpoint (camera angle, section planes) as well as visible/hidden items. At the same time it can add information like labels and comments. Assign to a person, ...
The huge benefit of using an issue manager (or BCF manager) is to keep track of open/closed issues. Set deadlines and assign issues to specific people to answer.
It is mainly used in BIM (coordination) based on IFC format. There are many viewers, like Solibri or BIMCollab Zoom, that include some sort of Issue Management. Even Navisworks has such a feature in combination with BIM360/ACC (not BCF compatible).
The main benefit in my opinion of such an open format is that it can work across multiple platforms. The modeller can use the BCF manager from their application (in case of Revit, Tekla, Allplan, Archicad, ...) while the person doing coordination can use a different application (Navisworks, Solibri, BIMCollab Zoom, ...). Stakeholders like designers or clients can use a (free) easy-to-use application (IFC viewer) to also check the model and make their remarks or answer the questions that are asked.
In my opinion BCF should always be used in combination with IFC exchange. It could work on DWG as well I guess. The most important thing is that all applications/models use the same origin coordinate. Otherwise those camera angles will be useless.
With OBD two very useful workflows can be thought of using BCF:
If there are more than one really good free viewers i would support that route.
My solution is more of a quick and dirty hack. But perhaps is faster to implement?
There are many free IFC viewers. Most of them good to very good!
The thing is that such BCF managers (those that are cloud based) are not free. They cost a bit (5-10 euro /user/month) but in my opinion more than worth it.
BCF can also be used as an "offline" file format. But that's not really ideal in my opinion. Consider a team of only 5 people all sending back and forth those files that you'd have to import each time. Changes are too big for messing up.
Concerning implementation in MS/OBD, I have no idea what would be quicker. If it's only a matter of exporting viewpoints it will probably be easier to implement that for DWG or 3D PDF if those file formats support such thing. But when you consider the bidirectional possibilities for other users to send back their comments or their own views I don't think it will be possible with such workflow. This is also why I suggested in the MS Idea to work together with an existing platform like BIMCollab who have done such implementations already for many other BIM software.
