I need to prepare rendering of design building In Open Building Designer.
The rendering need to be without sun light, I need to use only environment (physical sky) to match existing photos.
Does anyone know how to change environment colour as it is too blue at the moment.
Thank you very much in advance.
Mariusz
Hello Mariusz, Thank you raise you query. We have received your service ticket, SR 7001139158. It is under investigation.You will receive a resolution shortly. Thanks & Regards,Arindam Roy
Thanks Roy,
