OB7 UI responsiveness.. again
I made a fresh install of OB7, all defaults directories, DataSet_FR. High-end workstation, high-end graphic card, SSD drive, lot of Ram,...
I create a new empty drawing in BuildingTemplate_FR.
I press the Place Wall button. 3 seconds to open the property panel and let me choose a wall type. Then, right click to finish the command. 5 seconds to bring back the default command.
This lack of responsivness is a real pain. Not productive at all.
Can someone point me any workaround to speed up the UI ?
I suspect a heavy datagroup catalog or maybe Cells library or materials library. I really need maybe 10% of all these.
What is the best way to clean all this and have a very fast UI ?
regards,
Chris
