Looking to try and set up some more 'industry specific' types and items. I can create the types, but when I try and create the item list the system won't let me create xml files outside of the C drive.
What would be causing this?
What is the value of the variable _TF_WORKSPACEROOT? Does it match the location that you are trying to save to?
Marc
It points to the top level.
_TF_WORKSPACEROOT = C:\_CADmanage\Bentley\Standard\MSCE\
with Organisation files under:
C:\_CADmanage\Bentley\Standard\MSCE\OBD\Dataset_Carnac\
and Workspace and Workset under:
C:\_CADmanage\Bentley\Standard\MSCE\Workspace\Standards\.......
C:\_CADmanage\Bentley\Standard\MSCE\Workspace\Standards\Workset\.......
Hi Bear, have you checked to see if DG editor picks up the right folder locations?
Having an issue with that as well still.
Well, I guess until that's fixed then :) A quick check would be to see which location is picked by Catalog Editor as Organization location. Catalog Editor should at least show 2 paths used for catalog type definition, 1 should be "C:\program files\..." and the other one would be the Organization folder.
