Adding extra columns in the "Models" tool box
Was wondering if its possible to add extra columns into the " models " tool , so we can use them in a " custom expression " for printing PDFs in the way we would like to see
the way would involue having page names to be the same, which we have discovered cant happen under the " name " column in the provided image.
Hi Ben,
This request would require development to add a new property to the Models functionality.
You would need to file a Service Request describing what you are suggesting in more detail to enable us to file an enhancement request.
Alternatively if you could describe what you want to achieve in a bit more detail here, we may be able to make other suggestions.
Marc
