Copy or merge stair scales de object down
I have a model with some stairs modeled with the stair tool. If I create a new model with the same workset and same seed, and attach the first in the new one, if I merge the attachment or copy the elements, the stairs are sacled down 1000 times. OBD changes all the stair values that were in meters and "thinks" they are in milimeters or something. So the stair that was 3 meters high is now 3 mm high. Is anyone else seeing this behaviour? I'm using OBD U7 10.07.00.105.
