Why doesn't " move or copy or delete building features " tool work on new steel members in Update 7 ?
In U6 we work model a member, use " cut solids by curve " tool, then if we needed to move that hole, we would use the " move building feature " tool, but now it is saying " element not valid for tool "
How are we ment to move an polycut / hole a small amount without deleting the member and starting again ?
Hey Ben,
In U7 we have united ProStructures elements with our OBD. Please refer to this video to look how you can create a hole in Steel members. I hope this helps with your query. Regards,Alifur
