Hi everyone!
I have mechanical object (e.g. diffuser) with some drawing symbols:
I want to customize this top symbol.
How to understand where this symbol is located on my computer? And how it maps with drawing symbols in Building Element Info window?
OpenBuildings designer CONNECT - Version 10.07.00.105
Hi Denis,
I haven't looked at this in quite some time, but I think mechanical symbols may still be defined by the assigned Part as outlined in this (rather old) wiki: https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/5870/bentley-building-mechanical-systems-faq
Hi Steve!I saw this wiki, but it doesn't help
Sorry, this one fell off the radar. I've made a note against that FAQ since the Technote (former name for wiki) it refers to apparently doesn't exist. I remembered going thru this at the time many years ago but could not find any other reference to. It so happens that a few colleagues were discussing this same topic recently so I went back thru the steps to remind myself, and in the process created the attached Word doc. Hopefully this helps, if you still need it.
DOCX
Answer Verified By: Denis Borodin
Yeah, it will help me. Thank you, Steve!
You're welcome!
