So, I have a project with 3 different buildings, and so 3 different grids. We created floor plans for one of the buildings but they show all grids for all 3 buildings. How can we change this so it shows only the grid from the corresponding building? The "Set active grid" button is greyd out in all the floor plan models...
It looks like you are in a 2D Drawing or Sheet Model where these are greyed out.
Would toggling the clipping of the view volumes in the source design model help in this case?
Marc
Hi Marc,
I'm afraid not. We are modelling all the buildings close to the (0,0,0) so the grids overlap when we display all of them at the same time. Shouldn't there be an option to choose which to display in the drawing the same way we have for the 3D model?
Any ideas?
Hi Pedro,
Yes, I have a method that may work, need to document it before sharing.
Hi Marc, Did you document this process? Having the same issue. Grid options are greyed out in view attributes within the drawing file. I can turn on all grids but not selectively
