Data Group System Validator
Struggling with this randomly appearing “DG System Validator”, freezing everything. Then to shut down and restart the PC every time.
As I´m doing only small size projects in MStn I think I don’t really need the validation? I tried to change the User Config Variable “DG_Catalogs_Bypassvalidate” from 1 to 0 – but to no effect. Maybe wrong edit?
Do you know any other way to disarm this validation dialog?
Ingemar
Hi Ingemar,
Validation errors occur when parts of the dataset are not present or synchronised with the schema of the current application version. These are more likley to be causing problems than the validator itself.
Please can you tell us more about the version that you are using, dataset in use and previous version history? Have you recently upgraded?
Marc
