parametric cell bug
I got an parametric object with a variable x. If I change the variable, it behaves as intended. But if i save the parametric object to an parametric cell, it doesen't. I can reproduce this behaviour on two windows 10 machienes, with the newest version of OpenBuildings Designer CONNECT Edition. Showed the problem in this Thread, but got no answer: communities.bentley.com/.../loosing-constraints-from-creating-parametric-cell-from-parametric-object
How can I report a bug?
Best regards Ole
  • Hi Ole,
    Please can you send us a copy of the file? I have seen something similar, we may have already logged a defect, we can check.
    Please file a service request to to help us link you to an existing or new defect relating to this problem.
    Marc
  • Hi,
    I had a talk to some Service Members.
    The solution is to save the parametric cell in a different way.
    1. create a .dgn file
    2. model the object with variables
    3. in the window "variables": click on Variations and add a new Variation.
    4. Open the window "models": make the model to cell (click on "is cell" in the model row)
    5. long right click on blank drawing plane -> select "properties"
    6. in properties scroll down to cell: change from "graphic" to "parametric"
    7. save the file
    8. change the filetype in windows explorer to .cel
    For use in catalogs save the .cell-File to standard cell path.
    Good luck
    Ole
    Answer Verified By: Marc Thomas
