Hi
I have a problem with window views - the only views available are "Rotate" - dynamic, 2 point or unrotate. All the info I've found onlinerefers to a drop down menu on the "Rotate View" icon but this isn't there on my layout - any ideas ?
Cheers
Graham
Hi Marc
The course is BIM QuickStart for Energy Simulators Live Bundle for OpenBuildings Designer.
Changing the wall heights seems to be a bit of a problem, I've tried the old Hevacomp way but the values don't seem to want to change. This is the first time I've used the software so there may be a degree of user error.
Hi Graham,
The Energy Simulator room/wall height setting is a little different to Hevacomp as it cannot be changed after entering the room. It has however been logged for development so that this be function be incorporated.
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
ok thanks Shane. Apart from the issue with setting up the initial file really enjoying openbuildings - good upgrade.
Hi Graham, many thanks for the positive feedback, that's great to hear. If you have any other questions just let us know.
