Hi All
Could you please someone provide the link to download Singapore dataset for AECOsim Building designer (SS6). It is required for one of the project.
RK
Version 08.1109.866
Hi Rajeev,
You will need to file a service request to obtain the installer file as it is no longer available for direct download. the file that you need is abddataset_sg081109849en.msi, if someone else in your organisation has it installed you may be able to find a copy of this installer on your system?
Marc
