I would like to use profiles/sections defined in c:\ProgramData\Bentley\OpenBuildings CONNECT Edition\Configuration\Datasets\Dataset_UK\Data\Polish.xml but I can't find defined shapes in the list displayed during steel beams insert. When I'm displaying Shape catalog sections defined in the file mentioned above are not displayed as well. I will be grateful for some advice how to make file Polish.xml available.Regards,Bogdan
Hello Bogdan,
The structural shapes that you are seeing in the shape catalog dialog is coming from here: "C:\Program Files\Bentley\OpenBuildings CONNECT Edition\OpenBuildingsDesigner\Default\appl\Shapes\Poland.mdb" .
Those structural shapes are mainly Prostructures elements that we have incorporated in our OBD U7. If you want to use that specific xml file, then you need to convert the xml file into an mdb file to use it inside OBD U7 as the current version of OBD is taking the structural shapes from a database. You can have a look at this wiki to see how you can convert that xml file to an .mdb file..I hope this helps to clarify your issue.
Regards,Alifur
