I have a drawing (planview)
gridlines for the right building (IL-*) are showing correct, but also the grid lines from an other accompanying building (DC-*) are showing up in the drawing
In the 3D file, only the correct grid for the building is selected (IL)
how to hide the grid for the other building (DC- )
I have updated the floornames to unique ones (the where the same name in different buildings) with no result
OBD u6 &7
Hi Rik, we are looking into this after an similar question last week, the standard answer is a separate workset for each building but we are aware that this does not always fit peoples needs, we will report back here as soon as we can.
Marc
Option to define separate levels for the different buildings?
As a workaround, if you are using CVEs, you could hide the unwanted graphics. I think that the hidden elements stay hidden on reload.
That is correct, as long as the view is not switched back to Dynamic at any point.
That's a good workaround.
