OpenBuildings Designer CONNECT Edition Update 7
when I change space display units to m² & save settings.then next time when I open this file or create a new one, units just revert back to Sq mHow can I avoid this?
thanks,andri
Hello Andri,
I have tested the same thing in my environment. Can you please raise a Service Ticket so that we can raise a defect for this issue?
Regards,Alifur
Hi Andri,
You can set this by configuration as described here:
Spaces - Controlling Area Annotation
Marc
Answer Verified By: Steve Cocchi
thanks a lot. this helped.
try what marc suggested. it solved problem for me.
in openbuildingdesing go file>settings>configuration variables
& there add variable like this:
this adds line to settings file C:\Users\****\AppData\Local\Bentley\OpenBuildingsDesigner\10.0.0\prefs\Personal.ucf
but somewhy it won't be listed in configuration variables afterwords... but it seems working as long as m² is the only unit you want.
