Hello/
I am using aecosim building designer upd.3
In my working file i use references to see other constructions. Sometimes i need to change color of this constructions. I can change presentation of ref, but not color.
Anybody know how do this by easiest way?
No, they are not generated.
Listen, i am not talking about drawing model. only main model. in main window.
The Ref attachment on the right is coloured Green using the Adjust Colors tool.
You can also override the colour at the Level level.
1. Note that the Level Manager Symbology tab is set to Overrides
2. The overrides set in the Level Manager is for the Ref attachment not the active model.
3. BV needs to off for the view
Listen, you realy dont understand me. Maybe because i cant explain.
You are talking about reference in drawings. But i - about reference in model. I would like to see other model in my, then i use reference.
Those are both done in the Design Model.
Answer Verified By: Владислав Ахунджанов
