On Friday afternoon I spent about 30 mins doing drawing edits.
I had to undo a single line placement and it instead undid everything since I opened the file.
I tried clicking redo and it all came back....
I thought this really odd, so I saved the file and closed it.
I re-opened it to test and 'undo' appeared to work as normal, ie the undo button would only undo one step at a time.
I continued working for another 30mins, went to undo something, and again, it undid everything for the last 30mins, only this time it crashed in the process. When I re-opened the file I'd lost 30mins of work.
I understand there is now an option to "set a mark" in the undo tool - however I have not used this.
I have also been using the undo tool from the "standard" toolbox menu, not the ribbon menu.
I had the same (or at least very similar) issue last week. I can't say for sure if it undoes everything until the point where I opened the file, but it skips a lot of steps!! Both CTRL+Z as well as undo button. I'm not sure if Redo will make all changes come back.
Working in OBD U (10.08.00.44). I think the files where this happened have version control active. I'll have to pay a little more attention next time!
In ABD the menu>UNDO tells you what command is undone.
Not so in OBD ??
It can be very usefull, even necessary, to understan dwhat command you are undoing. It can be ouside your views or in another Model.
regards /Thomas Voghera
I completely agree! I suppose this is also a the case for Microstation Connect vs Microstation V8i?
We have this problem intermittently also Marc, It used to occur regularly in earlier versions of MS Connect but generally seemed to stop a couple of years ago, though recently I have had reports from users of the same. We are generally unable to replicate the issue so I have been unable to file any SR's on it. Only happens for some people, some of the time, not always the same people, but definitely not consistently across the office which leads me to believe it is some kind of prefs issue
