OpenBuildings Designer - Beginners questions 2
When working with OpenBuildings Designer I run into some uncertainties. Does anyone know a solution for this?
  • Units: When a new file is created with a Seed is selected where the Units are Meters and Millimeters, the created dgn file still have Feet and Inches as Master and Sub units. How can this be solved?
  • Floor Manager: I copied the Example workspace and now the Floor Manager is Empty and the seems to be no way to add a floor. What am I doing wrong.
  • Floor Manager: In the Example Workspace and Workset. When a value is entered in the floor tab, then the value has changed when apply is clicked (see image below / the units where set to m / mm).
Thanks in advance,
Louis van Amerongen
City of Amsterdam
Parents Reply Children
