Dwg workmode warning
I am trying to work on some dwg's in openbuildigns designer, but I keep getting the same warning about Prostructures and dwg workmode compatibility:
This pops up every time I open a file, switch between model spaces and save the file. Is there any way to turn off this warning?
With kind regards,
Jeroen
  • Hello Jeroen,
    The issue that you have reported is an known issue. We already have a defect filed the same.
    Defect number: 1103561.
    Can you please raise an service ticket so that we can attach the service ticket with defect number for tracking and to assist with prioritization.
    Alifur
  • Hello Jeroen,
    Thanks to raise SR 7001241266 and we have linked Defect # 1103561. Currently there is no way to switch off this dialog box. We will keep you posted if there is new update.
    Meanwhile as a workaround, you can continue using by clicking NO option.
    Similar issue was discussed in Forum.
    Hello I want to stop this feature because it could overwrite existing DGN's. And its taking extra time. Is it a variable for this to disable this. regards / Oskar
    Rajesh Agrawal
Reply
  • Hello Jeroen,
    Rajesh Agrawal
