Every time I launch the properties dialog box, OBD then becomes unresponsive with the only way to close it being through the task manager.
I have tested on models with box a large amount of data and then with a single line, and the issue is present in both cases.
The problem started after update to Version 7, so reinstalls have been tried including rollback to Version 5 but the problem persists.
Current OBD Version = 10.5.0.49
Any assistance, greatly appreciated.
Hi David,
Sorry for the late reply. The first "catch-all" step to try would be to generate a new set of preference files: https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/23227/regenerating-preference-files-to-help-resolve-random-odd-behavior
Next, if not already defined, try setting BB_DG_ECSCHEMA_CACHE to a local folder as outlined in this wiki: https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/22536/improving-datagroup-system-load-time-when-using-microstation-tools
