I created a custom railing asset using the place railing tool, but in some DGN files it doesn't show and plots properly. Either the profiles are too small or too big.
I fiddled with the drawing file units, profiles units, edited xml file units but the problem persists.
Any ideas?
Using OBD CONNECT Edition Update 7 - Version 10.07.00.105
Below using same library element in different files. Both files have the same Working Units settings
unexpected behaviour expected behaviour
**Moved this thread here from the Energy Simulation forum.**
Can you share some files please?
Brenden Roche
Applications Engineer
Bentley Systems, Manchester UK
Hi Gilberto,
Are you using legacy or ProStructures sections?
Marc
Hi Marc,
I'm using the "parametric" option from the shape name / railing construction settings tool. Not sure how these sections qualify, legacy or ProStructures.
I guess I could try and use the "Library" sections and see if I get the desirable results, but that would defeat the purpose of the tool allowing parametric sections.
Gilberto
