Hi
Small but very annoying thing. In my mdb-file for shapes all shapes have their names written in mixed lower- and uppercase letters (image1). x as in dimensions are for instance always lowercase. As it should be. But in OBD all letters are shown as uppercase(image2, middle column). This is not a big problem for designing, but when we use structural rules to show the section name on sheets it looks stupid. Is there a way to show letters in its correct case?
Robert
Hi Robert,
That is a good question... It looks like the lower to upper case transition is happening while mapping the legacy shape names to ProStructures names? But if so, what is the MDB table screen capture showing the lower case "x"?
Hi. I don't think it has anything to do with the mapping from legacy to prostructres. The shapes are all capitals even in a new file, that never seen legacy-elements:
Sorry, this is a defect that we need to fix, we will file one and and SR to link your question with it.
Marc
Answer Verified By: Steve Cocchi
Defect filed linked to SR 7001232268:
Defect 1126732:OBD-PS: Incorrect display of PS steel section size names (x's are capitalized)
