message center asks for:
"Architecture Configuration Check found error(s), please set _BB_SHOW_DATASET_LOAD_MSGS configuration variable and restart to see details."
nowhere is specified what this does, how to "set" "=1" ?
OBD u8
regards Rik
Hi Rik,
You are correct, we should explain that in this message and document in help.
setting it to 1 is the correct syntax. That is generally the case for on/off variables but we still need to be explicit about each case.
Marc
Answer Verified By: RikR
Filed Defect 1125448: "_BB_SHOW_DATASET_LOAD_MSGS Message Center text should include syntax for use"
Hello, we have similar error message in OBD Message Center: Architecture Configuration Check found error(s).
It affects automation iModeling process, the same error shows up in BAS which stop iModeling publishing. Please help us to solve this problem. Thank you.
Hi, next time you open the file please can you follow the steps in The Message Center - Some Tips to create a text file listing all of your messages then post that file to this thread. Many of the messages contain guidance that can help to resolve the messages.
Thank you Marc. I attached text file here. There is an error message which creates a problem: Architecture Configuration Check found error(s), please review the previous 3 message(s) for details.
Failed to update ProjectWise project information according to the current document - current project may be incorrect. Could not retrieve information from the CONNECTION client. SCHEMAMANAGERADDIN loaded. Title Blocks updated successfully! Updating Title Blocks... ...\H361269-1950-231-20M-0011.dgn Updating Title Blocks... Reading Section Reading: ...\dms20692\US_CraneRails.xml Reading Section Reading: ...\dms20692\CONCRETESHAPES.xml Reading Section Reading: ...\dms20692\FiberGrate-FRP-Shapes-2018.xml Reading Section Reading: ...\dms20692\American-Bolts.xml Reading Section Reading: ...\dms20692\projectshapes.xml Reading Section Reading: ...\dms20692\Misc_metric.xml Reading Section Reading: ...\dms20692\USERDEFINED.xml Reading Section Reading: ...\alla.remizova@hatch.com\dms20692\Canada_c.xml Reading Section Reading: ...\alla.remizova@hatch.com\dms20692\Canam_c.xml Reading Section Reading: ...\alla.remizova@hatch.com\dms20692\USA_c.xml Architecture Configuration Check found error(s), please review the previous 3 message(s) for details. COLUMNGRID loaded. File MechanicalMenu.dgnlib could not find SHX font [iso3098b]. Replaced missing SHX font [iso3098b] with [romans.bigfont]. File c:\pwworking\cacpwis01.corp.hatchglobal.com_pw__cac__datasource01\alla.remizova@hatch.com\dms09210\MechanicalMenu.dgnlib could not find SHX font [iso3098b]. Replaced missing SHX font [iso3098b] with [romans.bigfont]. Some text may not display correctly. Make sure that the appropriate SHX font file (*.shx) is present in a directory specified in MS_FONTPATH or MS_DWGFONTPATH. File MechanicalMenu.dgnlib could not find SHX font [ARCHITXT]. Replaced missing SHX font [ARCHITXT] with [romans.bigfont]. File c:\pwworking\cacpwis01.corp.hatchglobal.com_pw__cac__datasource01\alla.remizova@hatch.com\dms09210\MechanicalMenu.dgnlib could not find SHX font [ARCHITXT]. Replaced missing SHX font [ARCHITXT] with [romans.bigfont]. Some text may not display correctly. Make sure that the appropriate SHX font file (*.shx) is present in a directory specified in MS_FONTPATH or MS_DWGFONTPATH. Processing DV Dataset levels Reading: TFDIR_SETTING Reading: ...\dms21400\AnnotationOverrides.xml Reading: ...\dms21400\Concrete BeamFilterHierarchy.xml Reading: ...\dms21400\Concrete ColumnFilterHierarchy.xml Reading: ...\dms21400\Concrete PierFilterHierarchy.xml Reading: ...\dms21400\Concrete PileFilterHierarchy.xml Reading: ...\alla.remizova@hatch.com\dms21400\default.xml Reading: ...\dms21400\HatchAnchorageFilterHierarchy.xml Reading: ...\dms21400\HatchHandrailFilterHierarchy.xml Reading: ...\dms21400\HatchLaddersFilterHierarchy.xml Reading: ...\HatchStructuralSlab-Concrete-ExistFilterHierarchy.xml Reading: ...\HatchStructuralSlab-Concrete-FutureFilterHierarchy.xml Reading: ...\HatchStructuralSlab-Concrete-NewFilterHierarchy.xml Reading: ...\HatchStructuralSlab-Steel-ExistFilterHierarchy.xml Reading: ...\HatchStructuralSlab-Steel-FutureFilterHierarchy.xml Reading: ...\HatchStructuralSlab-Steel-NewFilterHierarchy.xml Reading: ...\HatchStructuralWall-Concrete-ExistFilterHierarchy.xml Reading: ...\HatchStructuralWall-Concrete-FutureFilterHierarchy.xml Reading: ...\HatchStructuralWall-Concrete-NewFilterHierarchy.xml Reading: ...\HatchStructuralWall-Steel-ExistFilterHierarchy.xml Reading: ...\HatchStructuralWall-Steel-FutureFilterHierarchy.xml Reading: ...\HatchStructuralWall-Steel-NewFilterHierarchy.xml Reading: ...\dms21400\JoistGirderSettings.xml Reading: ...\dms21400\MechanicalOverrides.xml Reading: ...\dms21400\PartMapping_sample.xml Reading: ...\dms21400\Settings_FFE.xml Reading: ...\dms21400\Settings_Frames.xml Reading: ...\dms21400\Steel BeamFilterHierarchy.xml Reading: ...\dms21400\Steel CladdingFilterHierarchy.xml Reading: ...\dms21400\Steel ColumnFilterHierarchy.xml Reading: ...\Steel Horizontal BraceFilterHierarchy.xml Reading: ...\dms21400\Steel PileFilterHierarchy.xml Reading: ...\dms21400\Steel PurlinFilterHierarchy.xml Reading: ...\Steel Vertical BraceFilterHierarchy.xml Reading: ...\dms21400\Timber JoistFilterHierarchy.xml Reading: ...\dms21400\Timber PlateFilterHierarchy.xml Reading: ...\dms21400\Timber PostFilterHierarchy.xml Reading: ...\dms21400\Timber StudFilterHierarchy.xml Reading: TFDIR_COMP Reading: ...\dms15136\Construction_comp.xml Reading: ...\dms15136\Space_comp.xml Reading: ...\dms15136\Structural_comp.xml Reading: TFDIR_CPART Reading: ...\dms15137\Architectural_cparts.xml Reading: ...\dms15137\Structural_cparts.xml Reading: TFDIR_PART Reading: ...\dms15171\Architectural_parts.xml Reading: ...\dms15171\Building_parts.xml Reading: ...\dms15171\Electrical_parts.xml Reading: ...\dms15171\Fireproofing_parts.xml Reading: ...\dms15171\HA_ABD_CE_230_M_Concrete-Bridges.xml Reading: ...\dms15171\HA_ABD_CE_230_M_Concrete.xml Reading: ...\dms15171\HA_ABD_CE_230_M_Earthwork.xml Reading: ...\dms15171\HA_ABD_CE_230_M_Energy_Structural.xml Reading: ...\dms15171\HA_ABD_CE_230_M_FRP.xml Reading: ...\HA_ABD_CE_230_M_Rock_Soil_Anchorage.xml Reading: ...\dms15171\HA_ABD_CE_230_M_Structural.xml Reading: ...\dms15171\HA_ABD_CE_230_M_Temporary.xml Reading: ...\dms15171\HA_ABD_CE_230_M_Timber.xml Reading: ...\alla.remizova@hatch.com\dms15171\IFC_parts.xml Reading: ...\dms15171\Mechanical_parts.xml Reading: ...\dms15171\Plumbing_parts.xml Reading: ...\dms15171\Reduced-Bentley-Structural_parts.xml Part assigned an unresolved material definition Could not find material definition $(_dgnlib)|building_materials.dgnlib|hatch232.pal : hatch232_gm_checkpl assigned to part: flooring - floor plate Could not find material definition $(_dgnlib)|building_materials.dgnlib|hatch232.pal : hatch232_gm_exist_checkpl assigned to part: flooring - floor plate Reading: TFDIR_SETTING Reading: ...\dms21400\AnnotationOverrides.xml Reading: ...\dms21400\Concrete BeamFilterHierarchy.xml Reading: ...\dms21400\Concrete ColumnFilterHierarchy.xml Reading: ...\dms21400\Concrete PierFilterHierarchy.xml Reading: ...\dms21400\Concrete PileFilterHierarchy.xml Reading: ...\alla.remizova@hatch.com\dms21400\default.xml Reading: ...\dms21400\HatchAnchorageFilterHierarchy.xml Reading: ...\dms21400\HatchHandrailFilterHierarchy.xml Reading: ...\dms21400\HatchLaddersFilterHierarchy.xml Reading: ...\HatchStructuralSlab-Concrete-ExistFilterHierarchy.xml Reading: ...\HatchStructuralSlab-Concrete-FutureFilterHierarchy.xml Reading: ...\HatchStructuralSlab-Concrete-NewFilterHierarchy.xml Reading: ...\HatchStructuralSlab-Steel-ExistFilterHierarchy.xml Reading: ...\HatchStructuralSlab-Steel-FutureFilterHierarchy.xml Reading: ...\HatchStructuralSlab-Steel-NewFilterHierarchy.xml Reading: ...\HatchStructuralWall-Concrete-ExistFilterHierarchy.xml Reading: ...\HatchStructuralWall-Concrete-FutureFilterHierarchy.xml Reading: ...\HatchStructuralWall-Concrete-NewFilterHierarchy.xml Reading: ...\HatchStructuralWall-Steel-ExistFilterHierarchy.xml Reading: ...\HatchStructuralWall-Steel-FutureFilterHierarchy.xml Reading: ...\HatchStructuralWall-Steel-NewFilterHierarchy.xml Reading: ...\dms21400\JoistGirderSettings.xml Reading: ...\dms21400\MechanicalOverrides.xml Reading: ...\dms21400\PartMapping_sample.xml Reading: ...\dms21400\Settings_FFE.xml Reading: ...\dms21400\Settings_Frames.xml Reading: ...\dms21400\Steel BeamFilterHierarchy.xml Reading: ...\dms21400\Steel CladdingFilterHierarchy.xml Reading: ...\dms21400\Steel ColumnFilterHierarchy.xml Reading: ...\Steel Horizontal BraceFilterHierarchy.xml Reading: ...\dms21400\Steel PileFilterHierarchy.xml Reading: ...\dms21400\Steel PurlinFilterHierarchy.xml Reading: ...\Steel Vertical BraceFilterHierarchy.xml Reading: ...\dms21400\Timber JoistFilterHierarchy.xml Reading: ...\dms21400\Timber PlateFilterHierarchy.xml Reading: ...\dms21400\Timber PostFilterHierarchy.xml Reading: ...\dms21400\Timber StudFilterHierarchy.xml Reading: TFDIR_COMP Reading: ...\dms15136\Construction_comp.xml Reading: ...\dms15136\Space_comp.xml Reading: ...\dms15136\Structural_comp.xml Reading: TFDIR_CPART Reading: ...\dms15137\Architectural_cparts.xml Reading: ...\dms15137\Structural_cparts.xml Reading: TFDIR_PART Reading: ...\dms15171\Architectural_parts.xml Reading: ...\dms15171\Building_parts.xml Reading: ...\dms15171\Electrical_parts.xml Reading: ...\dms15171\Fireproofing_parts.xml Reading: ...\dms15171\HA_ABD_CE_230_M_Concrete-Bridges.xml Reading: ...\dms15171\HA_ABD_CE_230_M_Concrete.xml Reading: ...\dms15171\HA_ABD_CE_230_M_Earthwork.xml Reading: ...\dms15171\HA_ABD_CE_230_M_Energy_Structural.xml Reading: ...\dms15171\HA_ABD_CE_230_M_FRP.xml Reading: ...\HA_ABD_CE_230_M_Rock_Soil_Anchorage.xml Reading: ...\dms15171\HA_ABD_CE_230_M_Structural.xml Reading: ...\dms15171\HA_ABD_CE_230_M_Temporary.xml Reading: ...\dms15171\HA_ABD_CE_230_M_Timber.xml Reading: ...\alla.remizova@hatch.com\dms15171\IFC_parts.xml Reading: ...\dms15171\Mechanical_parts.xml Reading: ...\dms15171\Plumbing_parts.xml Reading: ...\dms15171\Reduced-Bentley-Structural_parts.xml Cope Dependencies are disabled. Cope Dependencies are disabled. Copes will not be automatically updated. (STR_DISABLE_COPE_DEPENDENCIES) Connecting to ProjectWise... MCM loaded.
