message center asks for:
"Architecture Configuration Check found error(s), please set _BB_SHOW_DATASET_LOAD_MSGS configuration variable and restart to see details."
nowhere is specified what this does, how to "set" "=1" ?
OBD u8
regards Rik
Regarding these three messages, from the top down:
Two SHX fonts, iso3098b and ARCHITXT, used (presumably) by a DWG somewhere in the reference files are not available. If the SHX file(s) containing these can be identified and added to a location defined by MS_FONTPATH. The default value for this is C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\Default\fonts\, however adding SHX files in that location is obviously not efficient.
The best resolution would be for the people/organizations in the supply chain who still use SHX fonts to switch to commonly available Windows TrueType fonts, but this is not going to resolve your immediate problem. I suggest that your ProjectWise administrators do the following:
For info, hel says "If AutoCAD is installed, MicroStation searches for SHX fonts in AutoCAD’s Fonts directory (the "Fonts" folder in the installation directory of the most recently used version of AutoCAD). With or without AutoCAD, MicroStation searches the directories specified by MS_FONTPATH, as well as the same directory as the design file requesting the font."
The other error is that a material palette file, hatch232.pal, is not found. If this palette can be located and copied into a location defined by MS_MATERIAL it should be seen during iModel publishing. Any images used by the materials in this palette will need to be in locations defined by MS_PATTERN and MS_BUMP variables. It could be worth checking what hatch232.pal contains and if the materials are actually needed, they might be duplicates of standard materials.
Marc
Thank you Marc. I solved these 3 problems above but still have an error message in Message center : Architecture Configuration Check found error(s), please review the previous 3 message(s) for details. It's very confusing, hard to understand what 3 messages should be checked. Text file attached
Load setting file c:\pwworking\cacpwis01.corp.hatchglobal.com_pw__cac__datasource01\alla.remizova@hatch.com\dms15175\IFC_PropertyMapping_local.ifc2x3.set c:\pwworking\cacpwis01.corp.hatchglobal.com_pw__cac__datasource01\alla.remizova@hatch.com\dms15175\IFC_PropertyMapping_local.ifc2x3.set Load setting file c:\pwworking\cacpwis01.corp.hatchglobal.com_pw__cac__datasource01\alla.remizova@hatch.com\dms15175\IFC_PropertyMapping.ifc2x3.set c:\pwworking\cacpwis01.corp.hatchglobal.com_pw__cac__datasource01\alla.remizova@hatch.com\dms15175\IFC_PropertyMapping.ifc2x3.set Load setting file c:\pwworking\cacpwis01.corp.hatchglobal.com_pw__cac__datasource01\alla.remizova@hatch.com\dms15175\IFC_Mapping.ifc2x3.set c:\pwworking\cacpwis01.corp.hatchglobal.com_pw__cac__datasource01\alla.remizova@hatch.com\dms15175\IFC_Mapping.ifc2x3.set Load setting file c:\pwworking\cacpwis01.corp.hatchglobal.com_pw__cac__datasource01\alla.remizova@hatch.com\dms20719\IFC_Mapping_overrides.ifc2x3.set c:\pwworking\cacpwis01.corp.hatchglobal.com_pw__cac__datasource01\alla.remizova@hatch.com\dms20719\IFC_Mapping_overrides.ifc2x3.set Load setting file c:\pwworking\cacpwis01.corp.hatchglobal.com_pw__cac__datasource01\alla.remizova@hatch.com\dms15175\IFC_QtoMapping.ifc4.set c:\pwworking\cacpwis01.corp.hatchglobal.com_pw__cac__datasource01\alla.remizova@hatch.com\dms15175\IFC_QtoMapping.ifc4.set Load setting file c:\pwworking\cacpwis01.corp.hatchglobal.com_pw__cac__datasource01\alla.remizova@hatch.com\dms15175\IFC_PropertyMapping_local.ifc4.set c:\pwworking\cacpwis01.corp.hatchglobal.com_pw__cac__datasource01\alla.remizova@hatch.com\dms15175\IFC_PropertyMapping_local.ifc4.set Load setting file c:\pwworking\cacpwis01.corp.hatchglobal.com_pw__cac__datasource01\alla.remizova@hatch.com\dms15175\IFC_PropertyMapping.ifc4.set c:\pwworking\cacpwis01.corp.hatchglobal.com_pw__cac__datasource01\alla.remizova@hatch.com\dms15175\IFC_PropertyMapping.ifc4.set Load setting file c:\pwworking\cacpwis01.corp.hatchglobal.com_pw__cac__datasource01\alla.remizova@hatch.com\dms15175\IFC_Mapping.ifc4.set c:\pwworking\cacpwis01.corp.hatchglobal.com_pw__cac__datasource01\alla.remizova@hatch.com\dms15175\IFC_Mapping.ifc4.set Load setting file c:\pwworking\cacpwis01.corp.hatchglobal.com_pw__cac__datasource01\alla.remizova@hatch.com\dms20719\IFC_Mapping_overrides.ifc4.set c:\pwworking\cacpwis01.corp.hatchglobal.com_pw__cac__datasource01\alla.remizova@hatch.com\dms20719\IFC_Mapping_overrides.ifc4.set Failed to update ProjectWise project information according to the current document - current project may be incorrect. Could not retrieve information from the CONNECTION client. SCHEMAMANAGERADDIN loaded. Title Blocks updated successfully! Updating Title Blocks... ...\Hxxxxx.dgn Updating Title Blocks... Reading Section Reading: ...\dms20692\US_CraneRails.xml Reading Section Reading: ...\dms20692\CONCRETESHAPES.xml Reading Section Reading: ...\dms20692\FiberGrate-FRP-Shapes-2018.xml Reading Section Reading: ...\dms20692\American-Bolts.xml Reading Section Reading: ...\dms20692\projectshapes.xml Reading Section Reading: ...\dms20692\Misc_metric.xml Reading Section Reading: ...\dms20692\USERDEFINED.xml Reading Section Reading: ...\alla.remizova@hatch.com\dms20692\Canada_c.xml Reading Section Reading: ...\alla.remizova@hatch.com\dms20692\Canam_c.xml Reading Section Reading: ...\alla.remizova@hatch.com\dms20692\USA_c.xml Architecture Configuration Check found error(s), please review the previous 3 message(s) for details. COLUMNGRID loaded. Processing DV Dataset levels Reading: TFDIR_SETTING Reading: ...\dms21400\AnnotationOverrides.xml Reading: ...\dms21400\Concrete BeamFilterHierarchy.xml Reading: ...\dms21400\Concrete ColumnFilterHierarchy.xml Reading: ...\dms21400\Concrete PierFilterHierarchy.xml Reading: ...\dms21400\Concrete PileFilterHierarchy.xml Reading: ...\alla.remizova@hatch.com\dms21400\default.xml Reading: ...\dms21400\HatchAnchorageFilterHierarchy.xml Reading: ...\dms21400\HatchHandrailFilterHierarchy.xml Reading: ...\dms21400\HatchLaddersFilterHierarchy.xml Reading: ...\HatchStructuralSlab-Concrete-ExistFilterHierarchy.xml Reading: ...\HatchStructuralSlab-Concrete-FutureFilterHierarchy.xml Reading: ...\HatchStructuralSlab-Concrete-NewFilterHierarchy.xml Reading: ...\HatchStructuralSlab-Steel-ExistFilterHierarchy.xml Reading: ...\HatchStructuralSlab-Steel-FutureFilterHierarchy.xml Reading: ...\HatchStructuralSlab-Steel-NewFilterHierarchy.xml Reading: ...\HatchStructuralWall-Concrete-ExistFilterHierarchy.xml Reading: ...\HatchStructuralWall-Concrete-FutureFilterHierarchy.xml Reading: ...\HatchStructuralWall-Concrete-NewFilterHierarchy.xml Reading: ...\HatchStructuralWall-Steel-ExistFilterHierarchy.xml Reading: ...\HatchStructuralWall-Steel-FutureFilterHierarchy.xml Reading: ...\HatchStructuralWall-Steel-NewFilterHierarchy.xml Reading: ...\dms21400\JoistGirderSettings.xml Reading: ...\dms21400\MechanicalOverrides.xml Reading: ...\dms21400\PartMapping_sample.xml Reading: ...\dms21400\Settings_FFE.xml Reading: ...\dms21400\Settings_Frames.xml Reading: ...\dms21400\Steel BeamFilterHierarchy.xml Reading: ...\dms21400\Steel CladdingFilterHierarchy.xml Reading: ...\dms21400\Steel ColumnFilterHierarchy.xml Reading: ...\Steel Horizontal BraceFilterHierarchy.xml Reading: ...\dms21400\Steel PileFilterHierarchy.xml Reading: ...\dms21400\Steel PurlinFilterHierarchy.xml Reading: ...\Steel Vertical BraceFilterHierarchy.xml Reading: ...\dms21400\Timber JoistFilterHierarchy.xml Reading: ...\dms21400\Timber PlateFilterHierarchy.xml Reading: ...\dms21400\Timber PostFilterHierarchy.xml Reading: ...\dms21400\Timber StudFilterHierarchy.xml Reading: TFDIR_COMP Reading: ...\dms15136\Construction_comp.xml Reading: ...\dms15136\Space_comp.xml Reading: ...\dms15136\Structural_comp.xml Reading: TFDIR_CPART Reading: ...\dms15137\Architectural_cparts.xml Reading: ...\dms15137\Structural_cparts.xml Reading: TFDIR_PART Reading: ...\dms15171\Architectural_parts.xml Reading: ...\dms15171\Building_parts.xml Reading: ...\dms15171\Electrical_parts.xml Reading: ...\dms15171\Fireproofing_parts.xml Reading: ...\dms15171\HA_ABD_CE_230_M_Concrete-Bridges.xml Reading: ...\dms15171\HA_ABD_CE_230_M_Concrete.xml Reading: ...\dms15171\HA_ABD_CE_230_M_Earthwork.xml Reading: ...\dms15171\HA_ABD_CE_230_M_Energy_Structural.xml Reading: ...\dms15171\HA_ABD_CE_230_M_FRP.xml Reading: ...\HA_ABD_CE_230_M_Rock_Soil_Anchorage.xml Reading: ...\dms15171\HA_ABD_CE_230_M_Structural.xml Reading: ...\dms15171\HA_ABD_CE_230_M_Temporary.xml Reading: ...\dms15171\HA_ABD_CE_230_M_Timber.xml Reading: ...\alla.remizova@hatch.com\dms15171\IFC_parts.xml Reading: ...\dms15171\Mechanical_parts.xml Reading: ...\dms15171\Plumbing_parts.xml Reading: ...\dms15171\Reduced-Bentley-Structural_parts.xml Reading: TFDIR_SETTING Reading: ...\dms21400\AnnotationOverrides.xml Reading: ...\dms21400\Concrete BeamFilterHierarchy.xml Reading: ...\dms21400\Concrete ColumnFilterHierarchy.xml Reading: ...\dms21400\Concrete PierFilterHierarchy.xml Reading: ...\dms21400\Concrete PileFilterHierarchy.xml Reading: ...\alla.remizova@hatch.com\dms21400\default.xml Reading: ...\dms21400\HatchAnchorageFilterHierarchy.xml Reading: ...\dms21400\HatchHandrailFilterHierarchy.xml Reading: ...\dms21400\HatchLaddersFilterHierarchy.xml Reading: ...\HatchStructuralSlab-Concrete-ExistFilterHierarchy.xml Reading: ...\HatchStructuralSlab-Concrete-FutureFilterHierarchy.xml Reading: ...\HatchStructuralSlab-Concrete-NewFilterHierarchy.xml Reading: ...\HatchStructuralSlab-Steel-ExistFilterHierarchy.xml Reading: ...\HatchStructuralSlab-Steel-FutureFilterHierarchy.xml Reading: ...\HatchStructuralSlab-Steel-NewFilterHierarchy.xml Reading: ...\HatchStructuralWall-Concrete-ExistFilterHierarchy.xml Reading: ...\HatchStructuralWall-Concrete-FutureFilterHierarchy.xml Reading: ...\HatchStructuralWall-Concrete-NewFilterHierarchy.xml Reading: ...\HatchStructuralWall-Steel-ExistFilterHierarchy.xml Reading: ...\HatchStructuralWall-Steel-FutureFilterHierarchy.xml Reading: ...\HatchStructuralWall-Steel-NewFilterHierarchy.xml Reading: ...\dms21400\JoistGirderSettings.xml Reading: ...\dms21400\MechanicalOverrides.xml Reading: ...\dms21400\PartMapping_sample.xml Reading: ...\dms21400\Settings_FFE.xml Reading: ...\dms21400\Settings_Frames.xml Reading: ...\dms21400\Steel BeamFilterHierarchy.xml Reading: ...\dms21400\Steel CladdingFilterHierarchy.xml Reading: ...\dms21400\Steel ColumnFilterHierarchy.xml Reading: ...\Steel Horizontal BraceFilterHierarchy.xml Reading: ...\dms21400\Steel PileFilterHierarchy.xml Reading: ...\dms21400\Steel PurlinFilterHierarchy.xml Reading: ...\Steel Vertical BraceFilterHierarchy.xml Reading: ...\dms21400\Timber JoistFilterHierarchy.xml Reading: ...\dms21400\Timber PlateFilterHierarchy.xml Reading: ...\dms21400\Timber PostFilterHierarchy.xml Reading: ...\dms21400\Timber StudFilterHierarchy.xml Reading: TFDIR_COMP Reading: ...\dms15136\Construction_comp.xml Reading: ...\dms15136\Space_comp.xml Reading: ...\dms15136\Structural_comp.xml Reading: TFDIR_CPART Reading: ...\dms15137\Architectural_cparts.xml Reading: ...\dms15137\Structural_cparts.xml Reading: TFDIR_PART Reading: ...\dms15171\Architectural_parts.xml Reading: ...\dms15171\Building_parts.xml Reading: ...\dms15171\Electrical_parts.xml Reading: ...\dms15171\Fireproofing_parts.xml Reading: ...\dms15171\HA_ABD_CE_230_M_Concrete-Bridges.xml Reading: ...\dms15171\HA_ABD_CE_230_M_Concrete.xml Reading: ...\dms15171\HA_ABD_CE_230_M_Earthwork.xml Reading: ...\dms15171\HA_ABD_CE_230_M_Energy_Structural.xml Reading: ...\dms15171\HA_ABD_CE_230_M_FRP.xml Reading: ...\HA_ABD_CE_230_M_Rock_Soil_Anchorage.xml Reading: ...\dms15171\HA_ABD_CE_230_M_Structural.xml Reading: ...\dms15171\HA_ABD_CE_230_M_Temporary.xml Reading: ...\dms15171\HA_ABD_CE_230_M_Timber.xml Reading: ...\alla.remizova@hatch.com\dms15171\IFC_parts.xml Reading: ...\dms15171\Mechanical_parts.xml Reading: ...\dms15171\Plumbing_parts.xml Reading: ...\dms15171\Reduced-Bentley-Structural_parts.xml Cope Dependencies are disabled. Cope Dependencies are disabled. Copes will not be automatically updated. (STR_DISABLE_COPE_DEPENDENCIES) Connecting to ProjectWise... MCM loaded.
Hmm, it's not clear from the text file which errors are being referred to, we'll need a screenshot of the errors in the message center.
Also I see "Failed to update ProjectWise project information according to the current document - current project may be incorrect.Could not retrieve information from the CONNECTION client." You should talk to your ProjectWise admins about that.
