Clicking the Revision Cloud commands on OPB U8 results in "Unknown key-in or command"
Version 10,08.00.44
The key-in "Place revcloud points" and "...element" is not applied on these
I have filed a SR for this {SrvReqNo:[7001230108]}
Video
Hello Gerd,
Thank you for raising the service request.
When i am using the Key-in i can create a cloud by points. Please have a look at the attached image. But using the icon from the annotate tab, its throwing that unknown Key-in or Command. We will file an defect regarding this for OpenBuildings Designer.
Regards,Alifur
Answer Verified By: mlm
FWIW, this seems to be working OK here from the ribbon bar and via keyin:
If you haven't already done so, try generating a new set of preference files to see if that helps: https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/23227/regenerating-preference-files-to-help-resolve-random-odd-behavior
Hi Alifur,
yes thank you. That is what I get here.
Hi Steve,
that's interesting. I even have the issue after renaming the prefs folder though!
... Again loosing all my GUI setting accumulated ...
That reminds me that we could use a recovery tool for the case when prefs get broken - So I raised this idea
microstation.ideas.aha.io/.../MSR-I-648 PLEASE VOTE FOR IT
Hi Gerd,
Which dataset are you using? I'm wondering if perhaps that's the difference.
