When you export a SKP file it creates a version 2021 file. This is weird.
A good policy will be:
Export SKP -> 2018 or 2019 (or the most common installed versions or even the older version compatible with current sketchup version)
Import SKP -> the most recent version (2021)
regards,
xtov
Hello Chris, Than you for your post about SKP. We will surely look into this and updating you with further information. Thanks & RegardsArindam
Thank you Arindam.
Do you have a workaround for the moment because we can not use SKP file anymore : no SU 2021 and OBD U8 updated our precedent version. Is there an easy way to revert to OBD U7 ?
