Using OBD U8.
Has anyone been able to generate Floor Lines in OBD?
Maybe its a dataset problem? Cell not defined? Where would you look?
Hi Dominic,
Possibly a dataset error, however, which dataset install option did you choose? Have you installed a new dataset or one of the other choices?
The settings are here:
Marc
Thanks, Marc
UK Dataset
