I have got a question from our Revit users. They have been upgraded to Revit 2021 and are missing the Imodel plugin they had access to in the Revit 2020 version.
Are there any information of when the plugin for Revit 2021 are available for download
Best Regards
Ole Bro
Hello Alifur, maybe I was unclear. We don't have PW365, can I use this functionality?
Hello Johan,
Yes definitely. You would need to see if there is any projects for you in the Bentley Cloud Services (Connect.bentley.com) or not. I have attached an image. if you have something like the attached image, then you can use the functionality. Here you can see i have a connected project named Design Review. If you farther want to know, please do raise an SR, we can have a call & show you the workflow.
Regards,Alifur
We successfully tried the "Revit.ExportDWG.addin" copy from the Revit 2020 install to the Revit 2021 install.
But unfortunately the same copy to the Revit 2022 install does not work. We get an error message on the moment we want to export :
command failure for External Command. Revit could not complete the external command. Contact the provider for further assistance..
Will Bentley release a new Revit 2022 i_model plug-in please ?
Many thanks in advance,
Best regards,
Nico
Hello Nicolas,
The workaround would only work till Revit 2021. moving forward, to get Revit files in OBD, you need to follow the process as shown in the wiki shared by Mary Chib.
Hello Alifur,
Do you have any demonstration video showing to manually register the plug in for Revit 2021? Because I couldn't find the add in file inside there Revit 2020. Thank you.
