I have got a question from our Revit users. They have been upgraded to Revit 2021 and are missing the Imodel plugin they had access to in the Revit 2020 version.
Are there any information of when the plugin for Revit 2021 are available for download
Best Regards
Ole Bro
Interesting. Using the revit bridge doesn't seem to require a copy of revit to export. If so, a big step forward.
Dominic, That is correct, all you need is the Revit file, not the application.
Hello Mary & co,
Thank you for the tip. We tried this and it works fine, also for nwd files btw. We can attach these also as reference but we also would then like to be able to have (parts of) that reference i-model locally available. e.g. to copy the ref file in the active file. That seems not possible sadly.
We also tried the tip from Alifur and Mark and that also worked fine for 2021 .rvt files.
Many thanks everybody
Nicolas Tobbackx
I'm still new to the iModel and PW365 so I might have misunderstood when reading. But I take it you need PW365 to be able to use this workflow?
Hello Johan,
You can take files from PW to itwin by InstantOn. But here in the video of Mary has used connected project which can be defined by your company admin.
Regards,Alifur
