I have got a question from our Revit users. They have been upgraded to Revit 2021 and are missing the Imodel plugin they had access to in the Revit 2020 version.
Are there any information of when the plugin for Revit 2021 are available for download
Best Regards
Ole Bro
Hello Theint,
The addin would be found in %ALLUSERSPROFILE%\Autodesk\Revit\Addins\2020\, you need to type this in Run and then it will open the ProgramData folder. As per the snap, you are searching in ProgramFiles.
Regards,Alifur
Hello Alifur,
That's working now. Thank you so much.
Thank you Alifur,
We did indeed try the procedure on Revit 2022 and that did not work :-/
We still would like to have teh possibility to get a local copy of the i_model generated in the cloud. i_model generation for revit 2022 files worked OK in Bentley cloud but now I want that i-model physically local on my machine, not just a link.
Nico
Are there any updates to this thread from Bentley representatives? We need this plugin (or something similar) to work with Revit 2021, 2022 and new versions too.
Hello, Is there any further update since this response from Bentley. We need this add in (or another solution) to work with Revit 2021, 2022 and new versions in development too. Kind Regards. w.
