I am using the AECOsim V8i version.
In the sheet model, I have referenced the architectural & MEPF plan as a saved view. There are annotations (texts & leaders) as well.
Usually, the current model will be at the bottom in the update sequence setting. So that in the sheet model, text & leaders will come to the front and PDF will also be created accordingly.
Here is the new/strange issue. When I set the current model at the top in the update sequence setting, in the sheet model, text & leaders go back but in PDF it comes properly and visible.
Instead, If I set the current model at the bottom in the update sequence setting, in the sheet model, text & leaders come front but in PDF they are invisible. This problem exists in several files.
How to fix this?
Hello Santosh,
Can you share some images & files demonstrating the issue? It would be best for us to understand.
Regards,Alifur
You can put a vertex on the comment line, this will permit you to alter to course of the annotation on numerous occasions as you see fit https://pimion.com
Hi Bill,
"Vertex" doesn't work on key-in.
