Is it possible to hide the text "((none))" in layer names?
Hi Sedat,
Yes you can hide it by changing the level display format by keeping value of configuration variable 'MS_LEVEL_DISPLAY_FORMAT' = N. [N represents - Level Name , followed by description , as your level names does not have description it shows (none), Default value for this variable is N(D) and hence you are seeing this.
HTH,
Rg,
Sandeep
Answer Verified By: Alifur Mandal
Hi Sandeep,
Great!
This suggestion solved my problem. Thank you so much.
Kind regards,
Sedat AlisAEC Technology Inc.
