While testing U8, I noticed that dropping PS structural elements, with only "application element" turned on, will scale them down into tiny size if the following conditions are met:
- at least 1 dwg is referenced into the active model
- the dgn or model hasn't been re-opened since dwg attachment.
Test spec:
OBD U8 - BuildingTemplate_AU workset
Test steps:
1 - Open attached TEST_OBD_4.DGN
2 - Reference in attached TEST_OBD_4.DWG
3 - Without reopening TEST_OBD_4.DGN or switching active model, drop the PS structural element inside TEST_OBD_4.DGN using the following settings:
4 - PS element is dropped but scaled down.
TEST_OBD_4.dgnTEST_OBD_4.DWG
I don't assume this is WAD.
Best regards,
Tuan Le
Hello Tuan,
Thank you for doing the testing. I am also facing the similar thing with the mentioned. We will file an defect regarding this. Can you please raise a service ticket so that we can link the service ticket with the defect number for tracking and to assist with prioritization.
Regards,Alifur
Hi Alifur,
SR 7001234429 raised.
Defect 1127034 filed.
Hi Tuan,
I'm just curious - is there a specific workflow that requires dropping the ProStructures member?
