what is error (0x69e2cea0) and haw to prevent/repair dgn file
OBD U8
regards Rik
Hello Kirk, There are few questions i want to ask, 1. Is this a particular file you are having the issue with?2. Is there any particular workset you are facing this?3. Are you facing this issue when trying to open this file from PW?
Regards,Alifur
just one file, we use always worksets, we worked on the file, the day after - same machine, same workset: the file is corrupt (for now we have replaced it with an older version)tried an other machine, file can not be openedtried V8i u6, , file can not be openedif you want, I can send the file
Hi Rik,
Yes, please send us the file.
Marc
send
I have an other file with an error: 0x6a42cea0 who I can not open any moreCan someone repair the file?the file was on our server, was open on my machine true a VPN, the VPN closed while the file was still open,I have reopened the VPN, and left the file (auto saving is always on)When I now try to reopen the file, the file is corrupt
VCB_GC-poorten.dgn
thanks Rik
