Create a sheet / Add to sheet index / Rename Sheet model name ->> Seet index Link is dead, no way to update it. You have to delete it and manually add the sheet again.
Is this supposed to work like this ? You can not change a sheet model name after creation ?
regards,
Xtov
Hello Chris,
After linking a sheet index, once we try to rename the sheet name, it will give us a prompt saying that it will loose the link from sheet index. Please refer to the attached image.
We already have filed an enhancement for this item. Can you please raise a service ticket so that we can link the service ticket with the enhancement number for tracking and to assist with prioritization
Regards,Alifur
You get this message only if you select the sheet and right click "Rename". But if you just slow double click on the name (modern way to rename a file) you have no warning at all...
Hello Chris,Thank you for the response. Our development team is working on this. But as i have mentioned that we will be needing a service request to prioritize this enhancement
SR 7001235684 filled
