Hi Open Building Forum
I met a situation on the floor manager can't save my edition. Keeping change like the picture below.
The Message center shows up the Error the floor master( BB_FloorMaster )
then I check the dgnlib in the dataset, it seems didn't connect in my design file. because the date is didn't change. (not sure is this problem or not.)
Does anyone know what happens to it? Could tell me how to solves it?
Ps: I had test in another dataset, then the result is the same.
Open Building Version is obd100700105en_updt7
Lynn
Lynn,
Can you please open "BB_FloorMaster.dgnlib" [Typical path C:\ProgramData\Bentley\OpenBuildings CONNECT Edition\Configuration\WorkSpaces\Building_Examples\worksets\<WORKSET> \Standards\DgnLib" ] in OpenBuildings Designer and Open Model dialog . If you see only '3D Model' then fine, delete other models like sheet and drawing if you see them.
This will resolve your issue.
Best Regards,
Sandeep
Hi Sandeep Punewar ,
Thank you so much.
The "BB_FloorMaster.dgnlib" really has a sheet model inside. I deleted it.
Everything is fine now.
Thanks and Regards,
Answer Verified By: Sandeep Punewar
